Hello Peeps,
I have some questions about the rear handbrake. The other week I went to drive off after not driving it for about a month and found when I put the handbrake down it didn’t disengage so I couldn’t drive away. Today I found out it was the back left wheel that was causing the most issues so I took the wheel off and checked. The wheel didn’t budge at all so I took out my calliper key adjuster which you use with a allen key and untightened it. When I took off the calliper off the brake pads were actually stuck to the disc so I knocked them gently off with a hammer. I then put them back in and used the calliper key to get them tight enough that the disc didn’t spin with the handbrake on and put everything back together.
I was just wondering why it did this? I know the weather has been hot with summer but wondered if this will happen again?
Thoughts?
David
