MX5 Mk2 inner rear arch panels
Hi hope someone might be able to assist. Looking to find a pair of inner rear arch panels for MK2. Been unsuccessful in locating. Have a pal
who has rear panels with nothing to attach on to. Advise to date has been to scrap the car which seams a little drastic. Anyone suggest
where these parts might be available please.
Basically if someone is good at bodywork they can make their own panels. I probably do not have those skills.
You know get into is it worth the bother argument but I think it would be expensive to get one fabricated.
See:
https://mx5oc.co.uk/forum/yaf_postst17925_need-rear-right-inner-wheel-arch---sourcing-parts.aspx
1. There might be a part available from Mazda
2. Cut out parts from a breakers. I would think, Mk1 or Mk2, it makes no difference. At the very least, you are looking for something to provide a reference.
3. Source Escort part (Mark??), which seems like it might be fettled to fit (smashed to shape).
This is an unfortunate situation as no repair panel seems to be readily available.
A good fabricator should be able to fashion a part with relative ease but will need a pattern to work to.
In your position this will probably involve a trip to a scrapyard with a grinder to cut off the inner panel from a car with more material to work with than yours.
Most cars are scrapped because of corrosion in this area so unlikely but not impossible that you will find a re-usable section down the yard.
The Mazda part is called “Wheelhouse, Outer” or "Inner Pillar"
Left: NCY0-71-11X
Right: NCY0-70-11X
https://www.mazdanyparts.com/oem-parts/mazda-inner-pillar-ncy07011x
Its also included in "Panel Assy, Inner Quarter"
Left: NC10-71-100
Right: NC10-70-100
https://www.miata.net/garage/90-99Parts/NB_collision_guidepdf.pdf
https://parts.mazdaofwooster.com/oem-parts/mazda-inner-panel-assembly-n06770100
