How do you remove the passenger seat in the MK2 I have removed two front screws,but I can`t even seee the rear ones
I would imagine that you remove the ones at the front & pull the seat forward?
Sorry for the vauge reply, I’m in Scotland just now & mines is down in B’ham, collecting her again later today
Slide fully forward to see rear bolts
I thought I had slid it as far forward as possible I will push some more Len
Push seat as far forwards as it will go, tilt the back of the seat forwards and the 2 bolts will be visible at the ends of the seat runners.
Thanks I will try tomorrow ,I need to remove the seat and dry the carpet out ,then check the drain pipes at the rear of the hood.After that check the screen seal Len
