MX5Parts is selling a new Mk3 DRL and fog light kit (Linky), courtesy of IL Motorsport, for £175 delivered. Not exactly inexpensive, but I bit the bullet and ordered it, and couldn’t be happier.
This kit fits a NC1 out of the box, but does require some fettling of the inner OEM fog light trim for the NC2. The instructions recommend major surgery which removes one of the retaining screws; it turns out to be unnecessary if you have a Dremel with drum sander to hand. If you get this kit and try to fit it on a NC2 you will see the problem, and solution.
There doesn’t seem to be a way to embed videos on this forum, but if you want to know what the upgrade looks like in action here’s a Linky.
Just received my Kit direct from IL Motorsport, £152 delivered so a little cheaper than MX5P. I took advantage of a Halloween discount of 10€. Instructions aren’t exactly self explanatory to a numpty like me so I guess I might have to get someone to fit them for me.
I haven’t fitted mine yet but they come on with the ignition and when the headlights are selected they extinguish and then you may select fog lights if required via the standard switch.
Jim, just remove the liner will do, but not easy on a jack/stands - on a ramp you can do it easy as you have to mess around passing wires down and across the front behind the bumper. I must add I did not fit them, I took it to Michael at http://www.mx5expert.com/ for my yearly service and he kindly fitted them for me whilst on service. They are very bright.
Jim, they are worth every penny and you will be pleased with the result. The instructions are spot on and it is a DIY job I was just to lazy… and Michael is very helpful plus I trust him with my MX5 and these days that a hard thing to find.
Couple of questions if you dont mind.
Fit and mount the lights…ok, not a problem.
Plug into and mount the drivers…again ok, not a problem.
Now do you link the drivers together and simply run a pos and neg tap to the fuse box and let the drivers do their magic turning the lights on and off in the correct sequence?
