MX5 NA Wheel spacers with 15" BBS
Hi everyone,
I’m just about to get some Meister R coilovers fitted to my R-limited NA - super excited :slight_smile:
I’m thinking of adding some spacers at the same time, so I can get all alignment work done at once.
Does anyone know if 20mm spacers would lead to rubbing on the bodywork? I would ideally use 15mm spacers but I’m struggling to find any.
I have the standard 15" BBS Wheels fitted.
Thanks as always
Nick
15mm Hubcentric spacers with longer studs from Demon Tweeks.
Hub Buddies Hubcentric Wheel Spacer
Mazda 4 x 100 PCD, 54.1mm Centre Bore - 15mm Thick
https://www.demon-tweeks.co.uk/performance/wheel-spacers-and-pcd-adaptors/hub-buddies-hubcentric-wheel-spacer
Contact Stuart at Freaky Parts.
Will know far more about Mazda’s than Tweaks.
