- My model of MX-5 is: nc1
- I’m based near: Bristol
- I’m looking for technical help or recommendations on: Exhaust nuts and bolts
Hi all! I decided to bite the bullet and get an ebay exhaust. I asked if they included nuts and bolts before buying as I knew what kind of a rust bucket my car is. They lied in DM that it came with them and then told me I should have trusted the listing, not their dm, so now I have to source my own.
What size/type nuts and bolts do I need for my NC exhaust? If you can suggest links that would be grand
If removing the original back box they are captive bolts/studs in the flange.
Have a look on eBay for M10 bolts with nuts, around 25mm length thread. Stainless are best I reckon for this job.
Get a new ‘crush’ gasket to seal the flange to the mid pipe flange. Some supply a flat washer type gasket which I’ve found useless at sealing the joint
