From my understanding there was only 2 options here.
1.Standard 5 speed non-LSD with a 1.8L engine
2. Sport - this was the only way to get the 2.0L? and the sport only came with the 6 speed and the LSD?
Was this the case or was there other combinations too?
Does anyone have the options list for this car?
The standard 2 litre models had an LSD with a 5 speed box. The 1.8’s standard models came with a 5 speed no LSD.
Yes all Sports and the later Sport Tech of the NC2 were 2L 6 speed with LSD.
This below lists the models and specs…
Awesome, thats exactly what I was looking for, did not know there was a 2.0 5 speed!
makes sense now looking at the parts list, was not sure if the website I was using was accurate.
Next question, was there a difference in gearing between the 5 speed and 6 speed LSD?
And I am assuming the answer is yes, but can you swap between them, or is the dirve shaft bolt pattern different on the LSD between the 5 and 6?
Edit***
answerd my own question, looking elsewhere on your linked site gives the answer to the gear ratios!
nice resource there MickAP
