Hi All,
I recently had the two front springs changed out with replacement standard springs. (I know I know, it’s my wife’s car and she liked it as it was).
When it was first fitted I remember thinking both sides looked high (the drivers side maybe more so) the passenger side settled down after a week (and I heard a slight poing noise when reversing off a uphill parking space) but the drivers side didn’t and was about 1.5cm higher.
So I left it for 2 more weeks and took it back to the garage suspecting “twisted” bush. But they loosened off those bolts on both sides and then tightened them up with the car on the ground. It made no difference.
I have taken it on a 900 mile roadtrip which would have given it a good chance of bedding in, with lots of country lands and steering angles but the drivers side is still noticeably higher.
Any idea what it is, as the garage is pretty adamant these can only go back in one way. They mentioned when rechecking that there was some oil on the damper rod (both side) but to me that doesn’t explain why one side is more 4x4 than factory.
Any ideas ?
