- My model of MX-5 is: 1.8 NC
- I’m based near: Northern Ireland
- I’m looking for technical help or recommendations on: Front droplink replacement.__
- HI, could anyone please advise on correct way of replacing front droplinks on my 2007 NC.
After coming across conflicting methods online im not quite sure. The preload aspect of things seems to be the grey area …? Ay advice would be greatly appreciated.
I’ve done this job twice on two different NC’s, rears too. Don’t get too hung up about it, just swap them over fronts or rear just take the weight off the hanging hub when doing your final torque up.
To my knowledge it’s only important to sit the car on the ground when tightening up say a suspension swap or other suspension bushing to stop the bushes from twisting.
Great, thank you for the advice : )
As MickAP says - pretty straight forward job.
The only potential hurdle is corroded nuts on the ARB joints - they may need cutting off.
I always put the car on a pair of axle stands so the suspension droops the same each side.
This removes any twist from the ARB and makes fitting easier.
Thanks for the feedback … about to tackle replacing the links … hopefully not too many snags …
Job done, got her up on the axle stands, links off with bit persuasion(wire brush and penetrating fluid)
Replaced both sides not just the broken one, back from drive all good, handling great.
Thaks again for the tips…!!
