MX5 ND Brembo to Wilwood 37 Disc swap
  1. My model of MX-5 is: ND
  2. I’m based near: Brighton
  3. I’m looking for technical help or recommendations on: Sorry if this has been asked before; does anyone know if i can directly swap ND front Brembo discs for Wilwood Spec 37 slotted without any other changes? Also, what do people recommend for the rears? Fast road for a turbo stage 1. I’m running Endless pads currently.
Why not go for Dynapro 6 pot calipers and 12.88 discs which will give you all braking you require. Upgraded pads at the rear is all you need.
Thanks, i’m trying to keep the costs down as much as i can. You’re right, this will provide a huge amount of stopping power.
You are asking if you can go from a Brembo disc to a Wilwood one?
As long as it is the one for the MX-5, then it will be a direct swap. You should of course bed the pads in again, if you are not fitting new pads.
