Mx5 ND rear strut brace
ive recently become an MX5oc member and this is my first post so I hope I get it right??
Just wondering if anyone has fitted a rear strut brace in an MX5 nd. I’ve got he 2.0 sport Nav with eibach lowering springs and 15mm wheel spacers and running 215/45 Continental sport contact tyres. It already has front strut brace and for around £135 can get an iL Motorsport rear strut brace. It doesn’t seem like a lot to pay if it has a beneficial result.
Also just as a by word I recently had my alignment and geometry done at BBR and Neil McKay made a fantastic job of it really made a difference and highly recommend.
Any thoughts
DD
Hi, looking under the rear where does it bolt to ?
sorry ignore my above question, you mean the internal boot brace I guess.
Hi Yes the internal strut brace such as IL Motorsport or Cusco. ??
Hi DD,
I have a ND and I feel the steering to be a bit numb, not like an mx-5 at all. Do you know what suspension settings your car was set up to?
I’ve checked mine out and they’re as follows:
left front: 0 camber, 0 toe
right front: +0.5 camber, 0 toe
left rear: -0.6 camber, 0.5 toe in
right rear: -0.5 camber, 0.5 toe in
James
Hi James.
Bear in mind I have eibach Pro springs, 30mm wider track and running 215/45 tyres my numbers are (all applicable both sides)
Front Camber -1°16'
Caster 6°55'
Front Toe 0°04'
Rear Camber -1°30
Rear Toe 0°08'
If you can I would get down to Brackley and have yours done. I've had my car set up previously at the usual tyre centres and it was ok but after coming away from BBR my car just feels great. I imagine it's just down to lots of experience with different configurations of mx5.
Hope that helps.
DD
Did you end up getting a rear brace? Some seem like a bit of a awkward shape too and need to remove the plate that protects the fuel filler lines
I’ve got it fitted, no complaints, although I can’t advise the difference it made unfortunately as the following was done all at the same time:
Upgraded front strut brace, rear strut brace
Meister R GT1s
Eibach ARBs + adjustable drop links and Paco re-inforcement plates
Brand new set of Goodyear 215 tyres
Guardian Designs Corsa 330 steering wheel
So one great big bang change to the car (it was SORN at the time due to COVID).
Hi
I fitted the il motorsport rear strut brace and it made a world of difference tightened up the rear end, removed some skittishness and even seemed to help with pot holes and big bumps. It didn’t take too long to fit but was a bit awkward getting to the nuts on top of suspension fixings. One of the best mods I’ve done in terms of improvement per £ spent.
I also got a set of Delryn door bushings I went for the cravensport version but I think there are lots of options. Seemed expensive for what they are but again made a real difference to the solidity and made the car seem more solid.
DD
Bit of a bump - I fitted a rear upper brace today and was surprised by the difference!
The rear of the car feels a bit less “fidgety” and the steering is more direct. Kind of feels like 50% of the difference that was made from fitting a rear ARB to my old 172 Cup.
I wasn’t sure if I’d like it / it would make any difference, so only went for a cheapo one and haven’t done anything with the carpet and fuel filler hose yet, but I will do soon and post up some pics.
No affiliation with the seller of these, just amazed at the difference:cost ratio.
I am aware people are very different in how they view / feels things like this. I’m the sort of person who can be walking down the street and sense that a passing car has a worn nearside rear ARB drop link bushing :sweat_smile: So very much on the sensitive side.
My car is a very early 1.5 with Koni Sports, 6kg/4kg springs and no other suspension changes apart from alignment.
Will be trying other bracing shortly :+1:
I’ve got the 2 x upper I.L. Motorsport ones on mine, but it was impossible to know the difference they made as the car had a complete suspension overhaul (coilovers, ARBs, under body braces, steering wheel and a new full set of tyres at the same time). I also came from a 172, 225 and R26, the 172 was my all around favourite though.
Yeah I think that is the thing - loads of changes all at once masks / confuses where each has helped. I plan to do any bracing in stages to pinpoint what each one changes (hopefully!).
Those RS platforms make great cars huh :sunglasses:
Yeah that F4R was a fantastic little engine, it would have shown my MX-5 up out of the box (different story now its turbocharged).
Keep looking at the cusco rear brace to match my front. Need to drive more and spend less tho :joy:
