My Mk3 MX5 has just had a ‘check engine’ warning light come on and the local dealer can’t look at it for a few weeks and I need it before then. Does anyone know of an independent specialist in the Weston/North Somerset area? Thanks in anticipation…
Hiya, TBH, most (if not all) garages will be able to read your error code and more than likely fix the problem. Not sure if you’re mechanically adept but you could buy an inexpensive Bluetooth OBD11 reader and install an app on your phone ( if you have a phone) and have a look yourself? At least you would know the code, going forward. Might be something simple that’s throwing the dash warning light on.
As above, get it scanned, it’s probably a dodgy sensor needs replacing.
Thanks chaps, much appreciated…
