Hi Guys, a bit more info on the car as I have been researching / working on it!
The receipt from Skuzzle (Thank you Nick!)
ECU is an ME221,
Injectors are yellow so assume RX8?
Clutch is a Paddle version unknown brand but awkward in traffic!
and the Dyno result
My friend had the work completed, then drove it for a couple of days and added it to the storage barn with the other vehicles having quickly fitted a set of HSD coilovers (but clearly not setting them up!) The car then sat for a number of years at the back of the barn.
The day I purchased the car, it looked like this and was completely un-drivable!
The suspension had just been fitted to the vehicle and not set up in any way. the initial height settings were all over the place and the car wouldn’t clear potholes, let alone speed humps!
The heights were as follows:
Measurements were taken from the top of the arch to the top of the rim (not to the middle of the wheel as is stated in the FAQ)
Right Rear - 85mm / Left Rear - 70mm
Right Front - 72mm / left front - 96mm
Thats a 26mm difference between left rear and left front and 24mm between the fronts
After several hours of adjustment, we set the suspension up to the following:
Right Rear - 103mm Left Rear - 105mm
Right Front - 101 Left Front - 101mm
The suspension is now MUCH more compliant but the rear still bangs on the biggest of bumps in the road. The Damping is set to 8/16 all around.
From wheelarch to centre of wheelhub.
Front right 310 mm
Front left 310 mm
Rear right 313 mm
Rear left 315 mm
The plan is to increase the rear to 320mm once the new springs from Driftworks arrive as I have the old design! I will then get the new wheels fitted and get a 4 way suspension alignment.
rear shock setup:
I am planing on using the car for weekend fun and also entering a couple of Hill climbs / Sprints, so it needs to be reliable and setup well!
On collecting the vehicle, it was dropped off to my trusted friend for the following work to be completed as I was about to head overseas for a couple of months:
Welded diff replaced with a 3.6 TorSen unit with drive shafts and Prop, that I refurbed from my 2001 SVT donor car:
- Resolution of rough running (replaced plugs)
- Full under-seal including Sills
- Fitment of TR Lane roll bar
- Fitment of IL Motorsport bonnet lifters
The car was then collected and brought home to sort the suspension issues detailed above.
Since arriving back in the UK I have:
- Adjusted suspension as detailed above
- Replaced windscreen wipers with Bosch AR18U Aerotwin Retrofit Flat Windscreen Wiper Blade
Replaced Greddy air filter intake with RAM filter and silicon hose to reduce IAT
- Fitted DaveFab radiator panel
- Fitted Battery immobiliser / kill switch
- replaced dirty old ashtray with a cup holder
- Replaced original headlights with Wipac land rover units that I had in the shed with Phillips H4 bulbs
- Fitted new HT lead guides and routed leads correctly
There are still lots of jobs to do, but that’s the whole point of these cars!
The next job is to fit the new rear springs, adjust the ride height and fit my new wheels! Then its off to the alignment centre for a fast road setup (any suggestions welcomed!)
