Time for another update on the car! I barely used it over December and Christmas etc, it just sat in the garage with a tray under it acting as a giant nappy to catch the oil that was still dripping down… as well as coolant… nothing terrible, but not ideal either!
Over the Christmas period however I did buy the cam sensor O-ring as mentioned above by Steve - for only 2 quid from MX5 Parts it was a no brainer to give it a try even if it wasn’t the cause of the leaks! I also bought and paid for one of their single exit stainless steel exhausts, but it was out of stock at the time of ordering. This came mid-January. I also ordered (again on back order) a brand new Nardi Classic steering wheel and HKB boss from Driftworks. This arrived at the start of February, straight from Italy via Driftworks.
So with parts coming in, skip forward to the end of January and with the MOT looming in February, I booked the Eunos into my local trusted garage to have an MOT, exhaust fitting and to check for the cause of the oil and coolant leaks. The car failed the MOT at first due to leaking rear shocks (the Tein springs finished them off!) and it ended up being there 10 days so I was able to get the Nardi wheel fitted as well.
The MOT was sorted with 4 brand new shocks, one of the fronts was misting too so it was a no brainer again to have them all replaced at the same time. It was getting stupidly bouncy to drive anyway so it was no surprise really these would need changing. The coolant leak was discovered to be the actual thermostat housing - the garage told me they couldn’t get one so I got straight on the phone and ordered a genuine Mazda brand new one from MX5 Heaven with gasket and O-ring and also ordered a brand new Thermostat and gasket as well for good measure.
The oil leak was more challenging, baring in mind I’ve already had the rocker cover gasket changed with a new alternator belt, the oil leak never got any better, it simply sealed the top and pushed it out somewhere else - they stripped the engine down and there was oil everywhere, all over the cambelt and aux belts, down the block, a complete and utter mess… both front camshaft oil seals were badly leaking so these were changed as well as the CAM sensor O-ring i’d supplied.
Being put back together after a a big clean up;
This all ended being a massive job and in total, over the last 10 days the car has had quite a big over haul - new cambelt and waterpump, thermostat, thermostat housing, 2x aux belts, both front camshaft oil seals, the O-ring, 4 new shock absorbers as well as the shiney new stainless steel exhaust! But the results were worth it!
…. and finally, the new wheel fitted. It looks and feels fantastic, I went for the 360mm version, same as the original Momo wheel, as a smaller one would obstruct my view of the dials. The only annoying thing is that the Nardi horn push centre didn’t fit!? Something to do with the boss I believe so they had to put the Momo horn push back in, this is frustrating, but i’ll get it sorted asap.
The car now runs like a sewing machine with the work that’s now been done on it so i’m hoping fingers crossed i’m getting there with it now - fingers crossed that metal tray under the car can stay dry for a little while!
…. oh and the brand new yellow 2020 member sticker which came with the magazine yesterday has been added to my collection on the windscreen;
Anyway, hacksawed one end off and cleaned out the channels which despite looking pretty good, was still well worth doing! So this will be something to keep an eye on as my mohair roof is all good and doesn’t let in water.
