Well the best mod you can make for sure is to remove that horrible roll bar and sell it to me… I will make sure it is disposed of for you by fitting it to my Phoenix.
Welcome to the forum J-VW - lots of advice readily available here as and when you need it. Arches and sills a common problem - check out the drain holes in due course , also get undertray off and check out front chassis legs asap . Apart from that , enjoy the summer !
Hello and welcome! Am generally not a huge fan of non-popup lamp models of MX-5 but those Phoenix edition cars I really do like.
Just have a close check of the front chassis rails for crumbly rusting (where the anti-roll bar brackets attach) apply tonnes of Waxoyl inside and out if found to be sound.
Hi, your car is the same as mine, 02 silver phoenix edition , if your wheel arches have a few bobbles then I’d make that your next job, normally they rust from the inside which means I’d get the sills checked as well, the longer it’s left the more it will cost, I left mine for about 18 months and it’s just cost me £800 for a full over hall of sills and rear arches. Apart from that they are bullet proof and so much fun to drive.
