Can anyone shed some light on where my car may be leaking “fluid”?
I will start by saying the possible culprits in my opinion do not involve the following:-
Rocker cover. New gasket and correctly sealed at the corners. There is no sign of oil leakage from the cover.
Radiator (has been replaced and with new hoses)
New radiator cap (genuine Mazda)
CAS - 3 years ago and the car has covered no more than 3,000kms since
The steering rack does have a slight misting (left side as viewed from the front) and I am aware of this and will be seeking to replace it shortly. However, the misting is not sufficient to cause a wet stain under the car when the car has been standing 2 to 3 days.
The car is garaged. The car has been serviced thoroughly in March this year by MX5 Restorer and only covered a few 000 miles since.
The leaky patch appears to be more left side and towards the mid engine (when facing the car). Of course I am aware that a leak from elsewhere can cause the drop to form at a different point.
I’m suspicious of whether a seal has failed where the engine meets the gearbox/transmission?
Or that the patch on the floor isn’t oil but fuel? It isn’t a vast amount maybe tennis ball sized stain on the card under the car.
I am taking the car to Garath at MX5 Restorer on Wednesday but I am fearful of using the car for any long distance unless I can rule out that the car won’t suddenly drop its oil etc.
Please be gentle with me when answering. I am not an expert nor technically capable.
Yes I have booked the car into a garage so a solution will no doubt be forthcoming but I am merely interested in advance if any members of MK1’s have had a similar problem and the solution is relatively benign.
Any thoughts will be helpful.
Thank you.
