- My model of MX-5 is: NA 1.6__
- I’m based near: __sheffield
- I’m looking for technical help or recommendations on:oil leak
Hi all, I’ve got a oil leak which is a surprise as last summer the car had new front and rear crank seals, new gearbox seals, new cam angle sensor seal, new water pump and new rocker gasket…I can only imagine it’s the sump gasket but not sure if they’re typically a problem, anyone had similar?
