- My model of MX-5 is: 1993 Eunos Roadster 1.6
- I’m based near: Guildford
- I’m looking for technical help or recommendations on: I am refurbishing the front lower wishbones. I attach a picture of one of the alignment bolts. It’s pointing at “a quarter to”. Is there any way this could be correct? All the other front and rear alignment bolts are pretty close to top dead centre (+ or - “5 minutes”).
Also I would be grateful for recommendations for a torque wrench for use in a confined space. My wrench will not fit onto these front bolts, not enough space.
Could well be correct, only wheel alignment equipment can tell you. Is that alignment bolt even “spanner tight”? Can’t help with a torque wrench sorry. Maybe gat a crows foot to use on a conventional one.
