- My model of MX-5 is: 1993 1.6 NA
- I’m looking for technical help or recommendations on: Pop-up headlight motor crank stop position adjustement
Hello All,
At the moment my nearside headlight bucket stops a good 1cm above the bumper causing it to look like this and mess up the headlight beam level.
I’ve tried adjusting the headlight bucket mount (The one that’s mounted onto the chassis itself), the headlight lid and the rubber stoppers in the headlight bucket, but I’ve now come to the conclusion that this is due to the headlight motor crank stop position being incorrect, most likely due to something getting in the way when the headlights were lowered at some point.
I tried slackening the nut that’s on the motor crank arm (The one which is connected to the lift rod), hoping that would allow me to manually move it for adjustement but it wouldn’t budge and I didn’t want to force it for fear of damaging the motor.
I’ve looked online and been unable to find anything, so I wondered if anyone has dealt with anything like this before ? Is there anything I can do to re-adjust the crank stop position, without having to fully teardown and re-assemble the whole motor ?
