NA quarter panel fitting guide
Hi, I’m renovating a Eunos NA at the moment, replaced the drivers side sill and now attempting the rear quarter. Having trouble fitting this before I weld, does anyone no of any good online guides or video’s that I could follow please. Many thanks j
Mx5 restorer cover this repair quite regularly on u tube. It actually seems quite straightforward if you have reasonably welding skills as repair panels are readily available & quite cheap. Things become a bit more involved if the inner arch etc is rusty & you have to start fabricating repair sections for this yourself.
Ahh thank you for this, I will take a look. Yeah I’ve replaced the inner arch, and the rear quarter panel is proving to be very tricky.
