NA that's been parked up for several years
  1. My model of MX-5 is: 96 Gleneagles 1.8
My son has just purchased his first car, a 1996 Gleneagles 1.8 NA
Since 2016 it’s only really travelled 200 miles a year - Yes, just 200 hundred miles a year!
It’s been MOT’d each year, and any failure items have been fixed, but it’s on tyres from 2009/2010 and I’ve no idea when any of the fluids were last changed.
So, the current work schedule is 4x new tyres, new discs & pads. Oil & filter change.
Should I also replace all the other fluids too?
PSF
Gear Box Oil
Radiator Coolant
Brake Fluid
any thing else I’ve forgotten?
Possibly battery and check the clutch slave cylinder, these do deteriorate on these early models then leak. On brakes I would strip them down (when renewing discs/pads) to ensure everything is working freely and lubed. Belts too, cambelt and auxiliary belt
check if they’ve been changed.
I second this, i purchased a low mileage MX-5 NA from an auction, and about 2 months after purchase i was driving and the aux belt begun to squeak and eventually snapped while driving. Belts definitely being the first thing you wanna check.
I spent under a tenner on a brake fluid tester. Luckily my car tested as virtually zero but my wife’s car was 5% water content.
That’s somewhat high mileage, my Gleneagles has only done 30 miles in total since 2016 :wink:
Maybe do all the filters, not just oil? (so fuel, air and oil).
Go right through it if its a keeper, diff oil too.
Fuel filter is often overlooked but worth doing, dont buy a cheap one though, i had one from Autolink and it started leaking badly after 2 drives out which luckily happened in my garage.
Kavo brand i believe.
I use blue print stuff most of the time without issues.
