Does anyone know of a cargo net or storage solution for the NB? Something to keep small loose things from flying around in the boot (like a warning triangle). Need something a bit more than the existing cubby hole. Seen options for NC onwards but not sure if they are backwards compatible. Thanks.
Presumably not what you have in mind but I have a couple of these net pockets in the ND, one on the tunnel and one on the rear bulkhead.
When I had a Mk2, I had one of these small elastic nets with a wire hook at each corner under the boot lid with a few bits and pieces in which kept the boot floor clear.
Thanks John. Will check these out.
