Now the roof is up a bit more often I can smell hot engine oil inside the car when the roof is up, windows closed and heater fan on 1 with heat to cold.
I’m not loosing engine oil and there is no sign of leaks. Is this normal or do I have a blocked breather or vent pipe?
If so any ideas what might be blocked?
Nb has just turned 60000 miles and runs nicely apart from a bit of clutch judder.
If not the gearchange boots, have you checked CAS O-ring? I have the same issue on my white car, but know it’s because the O-ring is leaking. Job for next weekend.
MX5parts sell the boot, plus the lower one (the bit that fits to the gearbox turret) for £32 the pair (pattern parts) or £40 for the genuine Mazda parts, complete with a new lower nylon bush. Easy 10 minute job. Clean out and top up the gearbox turret oil, and you’ll have a shift quality like new.
