So I plan to install an Kenwood 8019 DABS headunit into my Mk2.5.
The unit has an input speed sensor cable which is required to be connected to VSS pulse harness.
Question is which cable can I connect to and where is it? I presume the standard head unit connector does not have it but I guess I might be able to pick it up around the back of dashboard.
This is all from memory as the car is now long gone.
I fitted a Alpine GPS, did everything except the washing up, head unit to my Montana 2.5. I recall I took the speed sensor wire from the rear of the instrument cluster, and it was white with a purple stripe.
I subsequently pulled the head unit to fit in my newly acquired MK1. This had no speed signal wire. So when I lost GPS ( going through a tunnel ) the GPS started "recalculating route ". Quite annoying…so find the right wire lol
Thanks, that will make it so much easier. The plan is to fit it this weekend, despite the rain looks like I will have to do it in the car port, and so a lack of natural light will be the enemy. I will let you know how I get on. I appreciate the feedback.
