Hi guys
I wanted to share my experience with the Cobalt short shift kit.
I know there is plenty on this topic already, but I wanted to add to this.
I should preface this with my opinion that the standard shifter is fantastic. If it aint broke, don’t fix it, right? Yes, right. But I am always trying to improve on things and frankly like to tinker and modify so I thought why not give it a go!
I installed the short shifter last December. The install is fairly easy, but it does take some finagling to get the feel of the shifter just right.
Along with the short shifter, I have also used a 2" extension with a Jass Performance teardrop shift knob.
Attached is an old picture, I have since tidied it up a bit and it looks a lot nicer now.
The shift is very nice, slick, and snickerty, exactly as I was hoping.
The downside is the additional noise, which has two different issues.
- The loud rattle seemingly caused by the internal reverse lockout spring (I have fixed this and will explain how below)
- The overall buzz/ vibration though the shifter due to lack of damping (I have not fixed this(yet))
The loud rattle caused by the reverse lock out spring has been fixed through the use of some small pieces of high performance foam with a very high rebound (I work for a foam manufacturer).
At first, I though this was the only issue, and I was pleased when it was fixed.
However as time went on, I began to notice more and more the residual buzz, which turns into a high frequency loud buzz at high revs (4.5k+).
This seems to be due to the fact that there is no damping on the cobalt shifter. I have tried to add some additional foam around the shaft under the gaiter, but this had had little to no affect.
My next step is to do a gearbox oil change, to see if that reduces the inherent vibrations coming thought the gearbox, but I somehow doubt it.
The reason for sharing this really is to give anyone considering the shifter a word of warning.
The shift is defiantly improved, but like all mods it comes with a price! I would personally not recommend this product currently. If I do manage to remove or reduce the buzz further, I will report back.
I hope this is of interest to someone.
If not, I’ll get my coat!
Antony
