NC 2.0 PCV Valve Change
Hi all,
My 2.0 NC is using quite a bit of oil, I’ve read that this might be because of the PCV valve under the inlet. I’ve had a look but cant seem to find a way of getting this off without what looks like taking the engine out. Is there a guide to do this? Else it looks like its staying off the road for a while!
Thanks!
You don’t need to remove the engine but it is a PITA job.
You will need to remove the throttle body and the plastic inlet manifold.
There is a thread on here describing the process.
