Nc bumper to plastic undershield fixings
Can anyone direct me to a supplier for the small bolts / screws that hold the plastic under tray with the bottom of the front bumper along the front edge
I replaced all the fixings in the previous NC1, IIRC, they are a 8mm hex head screw (more like a self tapper) I took one to my local nut and bolt supplier, they sorted out the nearest they could. The flange on the OEM ones are quite large, so I also got washers to suit the new fixings. Worked a treat  They aren’t seen  in normal use.
http://boltandnutsupplies.co.uk
