I fitted front fogs to my 2010 1.8 SE. Bought the kit from MX5 Parts and this came complete with a new steering column stalk which incorporates the two (rotary) switches necessary- one for front fogs and one for rear fogs.
So I think MickAP is correct…someone has fitted the front fog lights but hasn’t fitted the new stalk with the necessary switch to operate them. Cosmetically, they may have just liked the look of the fog lights instead of the black plastic blanking plates…but the wiring is there, accessible by pulling the wheel arch liner aside, and fitting the new steering column stalk is “plug and play”. I imagine the necessary stalk is available @ Mx5 Parts, or you could easily find one from a car with front fogs fitted as standard, in a breakers yard. Good Luck.
