I decided to make a heat shield and cold air feed to try and reduce the heat soak to my ITBs. Overall, im happy with how it turned out, although i havent completely finished. The cold air duct is behind the grille in the front bumper, as i didnt want to cut a hole out in the bumper. I havent had chance to measure the temperature either side of the heat shield when driving etc, to see what effect it has, but im hoping to do this soon.
How did your mod perform in real life Craig? I was thinking of going a different route by fitting an inline fan to the cold air supply feed and switching on in slow moving traffic as required or running off a itb mounted temp sensorso I’d be interested in your results before I crack on.
I haven’t measured the temperatures either side of the heat shield, so I can’t give exact numbers I’m afraid. What I can say though, using a non scientific method, is when I park the car in my garage after a drive, the strut brace, ITB air filter etc is cool to the touch, compared to the hot side of the engine components which are toasty. So it has to be making a difference. Since my original post, I have now also heat wrapped my exhaust manifold, which should be reducing under bonnet temps even further.
Cheers Craig
