Hi Folks,
Stupid question time, sorry!
I see lots of chat regarding the 2.0 NCs having a Limited Slip Differential. Can someone explain to the non-technical layman what an LSD is, and the benefits over any other kind of differential?
TVM
Hi Folks,
TVM
For road use, no real benefit, except bragging rights.
All of the factory diffs are torque sensing diffs, whether Torsen or Fuji. Get one wheel in the air, and it acts like an open diff. If you are fond of spinning your tyres all the time, I guess there is a benefit.
Not too sure that is correct.
A limited slip differential is there to âPreventâ wheel spin, (hence the name Limited Slip) in the main and therefore allow you via the cars wheels to put down more power on the road. This will also therefore give you more cornering grip. As it helps to prevent wheel spin it reduces wear on the tyres.
Google it. There is too much to re-type.
In short, a limited slip diff will only allow a limited amount of speed difference between the wheels connected to it. An open (ie normal or more common) diff will allow one wheel to spin while the other is stationary. The lsd therefore gives advantage of traction which helps in slippy conditions, or fast cornering, or on bumpy undulating roads (maybe not so much with the torque equalising diffs as opposed to the clutch based diffs). But again, Google is your friend.
For road use, if you are driving miss daisy THEN there is no difference. On tighter corners, particularly going uphill you can spin the inside wheel on an open diff, therefore losing power to the other wheel. This doesnât happen on a LSD
Hah, my 4.3 T2 diff inside wheel definetely span on that icey manhole cover when I smashed the car into the grassy bank all those years ago.
Torsen, whether made by Torsen or Hitachi, and Fuji are all torque sensing differentials. They are different to plated LSDs (âclutch type LSDâ, Drexler LSDs).
Have a read of this:
Then think about the torque bias ratio of the MX5 LSDs.
Torsen, whether Type 1 (93-95 Eunos Roadsters) or Type 2 (96-97 Eunos Roadsters, NB up to 2000, and 2004 Mazdaspeed (which used a Torsen diff made by Htachi), the ratio is 2.5:1. So the diff will supply 2.5x more torque to one wheel compared to the other. Torsen divides torque to the wheels without considering speed. If one wheel is on ice or in the air, the car doesnât move, like an open diff (2.5x nothing).
The Fuji Super diff is also Torque sensing, but uses clutch plates, not helical gears. I suppose this is cheaper.
Not my explanation, but Lance Schallâs, and he comes with a high reputation.
Doesnât DSC/TCS now do most of what is achieved by a LSD, for everyday purposes?
itâs pretty crude on traction control, it just cuts the power. Donât even start on DSC I drive with mine off.
This is probably the point where Timmy_T has gone for a lie down.
Thanks folks, but a lot of this is way above my head and level of understanding! đ”âđ«
Is there an easy description?
I thought the Fuji was preloaded and always gave some drive, opposite wheel in the air or not. Or for that matter being able to drive out of a muddy field when one wheel is proper in the mud!
Yes, as my first post and McTrucky.
Seriously, just Google Limited Slip Differential/LSD.
Read this link, just ONE example.
Zero is rarely zero, but the principle remains. Yes, the Fuji dff has some spring loading (36 ft/lbs to slip it), but it is still a torque sensing diff. The Torsen doesnât. Anyway, when lumps of metal (the taper ring, bits of the cone clutch)out of the Fuji diffs, who knows whether they are really functioning.
Another description.
Open differentials have a torque bias ratio of 1 to 1. That is, they will not distribute more torque to one wheel than the other. It is common to confuse wheel speed with torque. Do not fall into this trap. When one wheel is on ice, it may be rotating very fast indeed, but it does not take a significant amount of torque to turn the wheel on ice. The opposite wheel, on dry land, does not turn because it also has negligible torque (and in this case no speed either).
Another way of looking at the same idea is that the open differential can deliver no more than 50 percent of the available torque to any wheel. When both wheels are on a hard surface and the car is pointed straight, this is not a problem. 50 + 50 = 100. As you exit a corner and the lightly loaded inside wheel begins to spin, the torque to the outside wheel drops also. If one wheel is performing at 25 percent, the other is at 25 percent. The rest of the available torque goes to wheel spin or the driver is forced to lift throttle to avoid overreving/spin out. It is the loss of tractive effort from the outside wheel that racers want to eliminate. The spinning of the inside wheel does not matter much by itself. That wheel is lightly loaded anyway and can not contribute much to propelling the car out of the corner.
For cars with a solid rear axle, the driveshaft torque also attempts to rotate the axle about the driveshaft axis, lightening the load on the right rear wheel. It is as if the car were turning right even though it is going straight. This is a source of annoyance to drag racers who still use one piece rear axles.
Performance numbers for open differentials: 1 to 1 torque bias ratio. Since the second â1â in â1 to 1â is implied, sometimes you just see the first number 1 or 1.00 by itself. Sometimes the 50 percent figure is presented (see above) as the maximum amount of driveshaft torque (disregarding the rear end ratio) that can be delivered to any one wheel. 1, 1.00, 50 percent or 0.50 can all mean an open differential.
To the driver, the open differential is the safest, most forgiving system. Floor it coming out of a corner and you get less acceleration than you wanted and the outside wheel is still in rolling contact with the road, holding the rear end of the car in line.
With the car on a lift with the driveshaft constrained (in gear), turning one rear wheel will cause the other wheel to turn the other way. You should be able to turn it rapidly with relative ease. With the driveshaft free to rotate (gearbox in neutral), the internal friction of the open differential is probably not high enough to turn the driveshaft anyway and the result is the same.
Included here only for comparative purposes, is the all out racing setup; the spool rear end. The left and right tires are locked together completely, they rotate together. A spool rear end can deliver 100 percent of the available torque to one wheel (The engineer should note the maximum design torque load for a given half shaft has just been doubled!). The torque bias ratio is infinite (100 / zero). Performance number is expressed as 1, 1.00, or 100 percent.
A spool equipped car will break both rear wheels loose at the same time, exhibiting power-on oversteer (tail out power slide) exiting corners. Spool cars obtain some semblance of balance with ridiculously stiff front roll bars. This makes sure that as the rear end breaks loose, the weight transfer in the front is 100 percent to the outside wheel, so the front of the car slides away at the same rate.
You would not have a spool on your street driven Miata. If a spool is installed and the car is on a lift, the wheels will not turn unless the driveshaft is free to rotate. The wheels always turn in the same direction and speed.
There are two types of Torsen (TORque SENsing) differentials. Both are used on the Miata. The torque bias ratio in either case is about 2.5 to 1. This means that the differential is capable of supplying 2.5 times more torque to one wheel than the other. It is important to realize three things: First, the Torsen divides torque without regard to speed difference between the axles. Secondly, it does have a limit of 2.5. If one wheel is in the air or on ice, 2.5 times zero equals zero. The wheel on dry ground gets no torque and you are stranded just like an open differential. However, zero is never exactly zero and the Torsen is very much less likely to leave you stuck than an open differential. But still, if you try to support a torque bias greater then 2.5, the torque applied to the outside wheel will drop. And lastly, the Torsen does have friction clutches with the axial movement of the worm gears (under drive and coast loads) providing the necessary actuating force.
The 1994 and 1995 Miata have a Type I Torsen, which is the traditional worm gear unit. This device can be manufactured with a torque bias between about 2.5 and 5.0. The unit in the Miata is designed to about 2.5 or a little more. I do not have the exact number as it is actually verified through testing on the completed assembly. The 1996 and 1997 Torsen is a Type II. This unit has a different design with the worm gears being replaced by three sets of drive gears that are mounted with their axes parallel to the ring gear axis. It is simpler and less expensive than the Type I to manufacture. The Type II torque bias ratio (TBR)can be manipulated the same way, by changing the amount of helical twist in the drive gears although they are not as worm-like as the Type I. This design can be varied from a 1.0 torque bias (like an open diff) to about 2.5. Again, Miata is using approximately 2.5 or a little less.
For racing, the highest permissible torque bias ratio is usually desirable. Since the Type I and Type II are configured for similar torque bias ratios, it doesnât matter which one you use. The Type II is a fundamentally more robust design, but I have not heard of either unit breaking from track use. They seem to last forever. Off-road is another matter. The Torsen does not take kindly to rotational impact loads.
With the car on a lift, it has been suggested that the relatively puny force of you rotating one wheel, will not over come the internal friction of the Torsen. Both wheels rotate together. However, with the driveshaft constrained, the opposite wheel should rotate the other way just like an open differential once you exceed the TBR. Perhaps a bored member reader would like to experiment with some ropes wrapped around the wheels and those unused workout weightsâŠ
Since a spool will send 100 percent of the torque to one wheel (but has an infinite torque bias), the clutch style limited slip people needed a figure to describe how close their clutch pack approaches a spool. Take a torque bias of 5 to 1 for example: 5/(5+1) = 83 percent. An open differential at torque bias of 1 to 1: 1/(1+1) = 50 percent. Or a spool: infinity/(infinity + 1) = 100 percent. So the âstiffnessâ of clutch pack limited slip can be expressed as a percentage between 50 and 100.
To further complicate matters, the clutch pack limited slip (Kaaz) does not really have a specific torque bias. The clutch pack will support a given torque difference, behaving like a spool, until its threshold is reached. Then it slips, reducing the effective TBR, heats, and wears. To the driver, the car tends to push toward the outside of a turn with application of power. The left and right wheels are coupled together, it wants to go straight. You compensate by increasing the slip angle on the front wheels. When you lift, the front wheels take over, and the car pulls to the inside of the turn. As you approach the cornering limit, the push turns into power-on oversteer. All of this just to get out of the corner faster!
And the clutch pack wears out too. An additive is in the differential oil to allow the clutch pack function in an oil soaked world. By the way, friction modifier will also slightly increase the TBR of the Torsen.
With the car on a lift and driveshaft constrained, a wheel will show a considerable and consistent resistance to rotate (you are slipping the differential clutch). The other wheel turns in the opposite direction.
From 1990 to 1993, the Mazda Miata LSD was a viscous unit. This replaces the clutch pack friction material and preload springs with a bizarre fluid between closely spaced rotating plates. One series of plates is connected to each axle shaft. Speed difference between the axles causes the plates to rotate at a rate relative to each other. This shear rate (and shear rate alone) of a thin film of silicone enhanced fluid increases the fluidâs viscosity. Picture a beer mug sliding across the bar on a thin film of water. The increased shear rate (speed of the mug) increases the viscosity of the fluid, creating more friction. This allows the fluid to transmit torque (makes the beer mug harder to push). The beer mug and water really do not behave this way. Neither does gear oil. That is why a special silicone based oil is permanently sealed into the factory LSD unit. Regular gear oil lubricates the ring and pinion gears.
This is a speed sensitive (not torque) system. The difference in axle speed controls the fluid viscosity and degree of TBR. The friction available to the viscous clutch is limited by the operating characteristic of the fluid. At some point, the shear rate heats the fluid too high and it begins to breakdown. The fluid and size and number of the clutch plates limits the torque carrying capacity of the viscous unit.
It is excellent for helping a driver start moving from an ice covered road at a stop sign. This unit does not transmit enough torque to satisfy race drivers nor does it stand up to racing loads reliably. This comment is primarily directed at autocrossers (the poor bastards). The tight cornering in low gears is particularly hard on viscous LSD and is another reason the autocrossers ought to find something more interesting to do.
The test for a viscous LSD says a rear wheel must turn no faster than 3.75 rpm with 11 foot pounds of torque on an axle (page M-26 Shop Manual) with both wheels free to rotate and the driveshaft constrained. Although the shop manual does not give any more data points, the resistance to turn should increase with the speed of rotation.
In all cases of open differentials or traction aiding differentials (Torsen, viscous, or Kaaz) understanding what is going on at one rear wheel require us to know whatâs going on at the other rear wheel. For this reason, I donât see how we can call any of these systems âone wheel driveâ. And I have seen traction aiding differentials or transfer cases improperly explained in Road and Track, Car and Driver, and every major four wheel drive magazine. Make of this what you will.
And a supplemental discussion of VLSD:
Viscous couplings are generally not well understood and the Miata unit is no exception. First, it is thought to wear out. I think this concept is very overstated here. While there is no clutch plate contact, the usual notion is that the heat cooks the silicone oil and destroys it. This may be true and if so would be evident in demanding competitive applications. However, I suspect the opposite is true. The Miata VLSD doesnât get hot enough during an autocross to work effectively. Which brings us to the second point: the lock-up is lame anyway. Well, not if itâs hot enough.
Historically, the technical papers that indicate the beginnings of understanding how VLSD work date to the late '80âs and early '90âs, precisely when Mazda came up with the VLSD in the Miata. And they were proud of it, sending their service technicians to a special course on the VLSD. I remember one dealer mechanic confiding in me, âThey were so excited about the VLSD, I thought it would be on every Mazda carâŠâ
Now, the alternating plates in the VLSD are toothed wheels with a couple dozen radial tabs. The reason for this is to eliminate warpage of the plates with temperature. Turns out there was some serendipity to this design. It has long been known that VLSD transmit more torque than estimated by shear forces alone, sometimes 10 or 20 times more torque! But sometimes NO more!(?) Engineers had been muddling along with empirical test results until about the '90âs when several scholarly attempts were made to quantify and predict performance.
It turns out that the plate tabs twist and shift axially giving rise to all sorts of interesting phenomenon with fluid phase changes, bulk pressure, dissolved air, Coulomb friction, blah blah blah (see SAE 2004-01-0867 - Mohan). The short story is the VLSD differential enters an operating phase Mohan calls âSelf-induced Torque Amplificationâ (STA). This is also described by engineers working with Nissan, Takemura and Niikura, although they call it âhumpâ (SAE 900558).
In any case, the VLSD has 3 phases. First is initial viscous dissipation where the oil heats and viscosity drops. The VLSD transmits less torque. This is the operation you can measure with a torque wrench as outlined in the Shop Manual and gives rise to the idea that the VLSD is lame. As the fluid heats, the transmitted torque levels and at last in the final phase, as the fluid temperature exceeds 200 C, the torque graph shoots up, with a very steep slope, to transmit 300-400 ft-lbs or more. The ability of the VLSD to transmit this torque will continue as long as the high shear rates are present. To achieve this temperature, the VLSD may have to be subjected to high shear rates for several minutes. Clearly, this is not accomplished at an autocross or even, perhaps, on the track. So, the poor reputation of the VLSD for typical Miata performance applications is supported by the scientific explanation. However, this continuous shearing may be experienced in off-road center differentials and, indeed, Mohan worked for New Venture Gear and viscous differential are still found on 4x4 vehicles here and there.
So, the Miata VLSD is probably not weak or broken, just poorly matched to its application. If it DOES break, it can be overheated oil, or broken tabs on the âcluchâ plates, or I suppose the fluid could leak out. In any case, the unit is not serviceable and one suspected of being defective is discarded.
You notice Mazda dropped it and moved on to the TorsenâŠ
