NC MK3 Front grille
Hi Folks
I need some assistance, just purchased a new Front bumper mesh grill from ZUN products. I have a front grille with a chrome surround factory fitted (Niseko), on attempting the new mesh grille installation (told very simple) I realised the chrome surround must be removed, there lies the question!
Can anyone advise on the simplest way to remove this surround, I first tackled the number plate and stopped there, no idea how to take this off without brute force, not my way!
Looking into other forums I found a method of removing the front bumper…very good, however there looks like two screws which need to be removed first…are they behind the number plate !
Appreciate any assistance.
Thanks Mark
If it’s not screwed on it has to be glued on, mines screwed on so the next bit of advice I’ll leave for you to decide  , either use brute force or try some fishing line or similar to ‘cut’ the plate off. Otherwise bumper removal is fairly straightforward , it’s easier with the weight off the wheels as you need access to the liners which requires wheel movement.
I remember reading about certain grills not fitting the chrome surrounds: Is it this one? http://www.mx5parts.co.uk/zunsport-woven-mesh-grille-mk3-p-2170.html
 As it will not fit a Niseko Grill:
‘Please note: These will not fit Launch edition or Niseko models with the chrome trim around the grille mouth. Also, only vehicles with a standard UK sized number plate as they have been designed to fit around them for ease of fitting.’
Oh and the two screws you are talking about are behind two pieces of the plastic grill: http://www.mx5parts.co.uk/front-bumper-grille-insert-mesh-type-mk3-p-3505.html Just pull the plastic away and the screws are right behind
Hi PDRAKE007, Stevieh
What can I say but not sound more stupid than I feel.
I went to ZEN SPORT  no such mention of which style NC it wouldn’t fit! http://www.zunsport.com/en/mazda-mx-5-mark-3–upper-grille-p118
Appreciate your confirmation, this has saved me a lot of work, tonight I was planning removing the bumper!
Now I have very a cheap and in perfect condition NC grille for sale!
Any advise on suspension? I am looking into Eibach springs although WARNED watch the weight issue with a hardtop version, Mazda wont fit them, looking at the wheel arch gap to tire, I don’t believe I will have that problem! so may purchase and fit myself then a professional geometry check!
If Zun Sport don`t mention it not fitting various models, could you not send it back for a refund?
Yes I would contact them over this, can’t refuse surely.
Got mine direct from Zunsport and yes a simple fit with a standard grille.
Contacted ZUN Sport, very helpful and agreed to take back the grille at full refund, they will look into updating their site where they are specific to grille vs MX5 models.
Unfortunately I didn’t get what I wanted, but lesson learned will be asking you folk first!
Cheers all
