You did indeed Neil. Firstly, I was embarrassed to have taken you up on your kind offer of talking me through it all on the phone You would have probably hung up on me in the end
Now, let’s get on to the good news! I’ve only gone and done it
I think that miracle I asked for, actually happened I’m just off to put the lottery on
My biggest issue was being able to enter the extended licence ID into Forscan. That, to be fair is totally down to me, nothing to do with the overall guide published by Neil. I tried saving the downloaded extended licence details all over the place without success. Then, following on from Neil’s earlier post, I
created a new folder in my C/ drive, named it and saved the download within it (I think) anyway, went back in to Forscan, clicked load code or whatever it asks for, searched in C/drive for it, clicked it and there it was!
Closed down and reopened Forscan, everything was there literally a couple of minutes following prompts including getting the in code off autokey site, which was literally just logging in, click FORD, enter outcode, click generate and there was the incode. Back on Forscan, entered the new code. Then you have to remove original key, swap it for the new key, turn ignition back to ON, click OK on Forscan page and literally one second and it was programmed! I didn’t believe it so turned key and car roared into life!!
there were two keys registered on the ECU, now there are three, of which I have two.
I always knew it would be easy
Massive massive thanks to Neil for providing this information in the first place, cannot thank you enough mate! Also to all you guys that have contributed on Neil’s thread regarding this fantastic method.
