Has anyone tried the following?
Is it any good?
It’s certainly cheaper than the real Smart Top module. Not too sure about delivery costs though
Is it any good?
They have UK/Europe dealers. Click to buy and it should take you there. £149 on my ipad.
Lots of writeup on this on miata.net so have a look there. Maker is very active on there. I have his ND window closer module and it works fine.
Had the original on my NC and really liked it. Nice to be able to close the roof at traffic lights and not worry about not being able to drive off if they changed to green. I had set mine at (from memory) a 15 mph speed limit on being able to close the roof whilst moving.
Hi unfortunately I do not have the alternative module so cant really say much about it. However I do have the Smart Top module and that works perfectly.
From personal experience with purchases and goods, I usually I get my moneys worth so I don’t particularly buy cheap stuff.
However if there is a competitor is good for us. They way I see that if there is a competitor then there is no more product monopoly hence the prices will become more competitive.
Hi, I realise this thread dates back a couple of years but thought I’d add my experience of purchasing and installing the one touch roof controller. Calling it ‘Smart Top’ may refer to a company selling it in which case I didn’t buy from that source. I like many others saved quite a few quid and got one from MXThings. Roof Controller for Mazda MX-5 NC PRHT – MX5things
Pack hade everything in it to do the job. Link to download exe file is included and although first method for Windows didn’t work second did. The use of a pc/laptop connected with the black control box is to set your preferences eg speed limit for roof permissible opening (max is 30mph & is the default). I was happy with all defaults viz. unlatch and roof automatically retracts down. One touch on up button and roof raises, then you just latch lock it as normal. … and … it works. fantastic. However that’s not why I am writing here. There are reports that getting the existing white plug connector out of it’s socket can be troublesome (other words are unprintable). Some guys have not had this grief. I’ve read comments like it can take 5 mins or 45 minutes. We, I had a mate with me and in fact his fingers took most of the strain, tried and failed to remove this connector. The central clip was on the non-visible side of the connector where access is extremely tight. neither mirror or moblie phone could shed light or picture of what we were looking for. We did not give up, the job was done and nowhere have I seen this advice which I’m about to impart. No doubt as it’s so obvious others have gone this route before me and maybe it’s on UTube but I hope this helps.
The unit which you need to swop over connectors has two other connectors plus some chunky wiring so access is poor.
We just unbolted the main metal unit pulled it into a slightly better positioned so the smaller middle connector (earth was disconnected on battery) and right hand connector could be disconnected. This gave us a bit more wriggle room and with a bit of jiggling and manouvering took out the whole unit.
Now, that’s a great way of doing it. Twill hopefully help others. Tis a great piece of kit at a fantastic price.
Great write up! I have one question, did you have to declare this as a modification to your insurance and if so, what category does it go under?
Having fitted my SmartTOP module to 2 different NCs, I would suggest that the way to disconnect the “awkward” electrical connector is to have the roof half open - this allows easy access to the tab which needs to be pressed in order to separate the plug from the socket. Any other dismantling is not required.
Also, be aware that the “maximum” speed is the maximum speed at which the unit will START to operate. Once it has started, you can drive at any speed and it will continue to open/close. (Obviously I would suggest driving as slowly as conditions permit until operation has ended, to avoid putting undue strain on the mechanism).
Jac(k), only just seen your question re insurance. Long answer short, no. Never occurred to me. Then it got me thinking should I declare the stubby aerial? I have declared coilovers and changed tyre size. Now you’ve got me worried. Happy days.
I have one on order, spoke to my insurance company Saga who said it needed to be declared and have added it to my policy for no charge.
With insurance its always best to fully disclose any changes.
Hahaha, sorry about that. But with regards to the stubby antenna, I asked my insurance about mine and they said it didn’t need to be declared.
Did they say what category of modification they would put it under? A few weeks ago I spent 10 minutes on the phone trying to explain to my insurance what a gear stick gaiter was
I can’t even imagine trying to explain to them what a PRHT controller is, lol.
Since I never declared it I’ve no idea how the insurance world copes with such things. perhaps its an urban myth but I was told that even stickers should be declared if on the outside of the car (not inside windscreen eg Club’s membership year sticker). Oh and then there’s stone chips which are not original to the car - I’m showing my cynical side now.
Or the driver or the passenger! It’s all a bit silly tbh.
The plot thickens.
I contacted my insurer, happens to be Saga same as Chletenham _Venture above, and after an hour’s to-ing and fro-ing I still await their decision. Underwriters are being consulted (again) and I’ll hear back. Amazing after at least one of our number has already got this passed by Saga. Love my Mk3.5 PRHT but maybe I must get a MK4 1.5 keep it original and save some pennies.
