Hello, folks.
When cleaning my PRHT panels I noticed this piece seems to be broken off. Not sure what it’s purpose is. Does anyone here know?
It looks like the bottom part has broken off in the top section on the roof, the base should looke like this:
And you can see both parts on the parts diagram here:
Specifically:
- R1-930A
- R1-9B1
They are listed as a ‘Wedge’ and look like they are for aligning the cover when it closes
My guess is that it was shunted at some point causing the wegde to break
I hope this helps
Thanks! The wedge seems to be stuck in the top section but everything appears to work correctly.
