NC wheel alignment
Looking to have the alignment sorted on my NC. Keeping the standard 4x4 springs but would like the wheels all pointing the right way.
I’ve found a place in/near witham called tyre smart. https://www.tyre-smart.com/wheel-alignment
Anyone used them before?
Also they say they will align to the manufacturer or your supplied specs. I’ve heard great things about how these cars go better when aligned so are the manufacturer specs the best or are there better ones out there? If so where can I get hold of them?
Thanks in advance
If I was you, I would get myself over to WIM; it does MX-5s on a daily basis…
Obviously they would be my first choice but Witham is just around the corner, Chesham during the day from here is a horrible drive, and that’s coming from someone who drove to Scotch corner for a hardtop!
I can recommend http://www.bccarsmotorsport.co.uk in Haverhill.
Brian did my fast road set up (for AutoSolo), but if you tell him how you want the car to drive he will listen and set it accordingly, be it road , race, or in-between.
Not expensive either.
Paul G
