- My model of MX-5 is: __ND
- I’m based near: __Newquay
- I’m looking for technical help or recommendations on: __we have had our ND for 3 years and all was fine. Now the battery is going flat when the car is not in use. We charged the old battery…same thing. Bought a new battery…same thing. I have turned off all the heating and fans, interior light, boot light, radio etc.
I read about a software update, but everything has been fine for 3 years.
Just been out to it again and it won’t even unlock.
Any advice welcome.
Many thanks.
This thread below could give you some pointers to check, it’s a long one though but could highlight something you’ve not checked
Do you have a multimeter?
Having checked all the obvious you will need to remove each fuse in turn to identify which circuit is drawing current and then take it from there. It will have to be a patient process of elimination.
Please let all of us know what you find.
Leaving cruise control on I am sure used to be an issue too
Thank you. Will do.
Cheers
Yes, I have turned that off too.
Thanks though.
Thanks Mick.
Have you got a dash cam installed? Or anything in the 12v socket in the passenger foot well?
No to either one, but thank you.
