ND - Catted Manifold arrived (with Pics)
BBR catted manifold and center section arrived .
was suppposed to be with caliers… but think they forgot to combine the orders. nooo. cars off road due to seized calier)).
so ,this weekend means exhaust fitting instead. (it didnt ship with gaskets though… need to source some)
come pics for those who like pics.
has anyone fitted this themselves and got any horry stories to tell before i crack on?
I believe you may have to undo the engine mount to remove the oem manifold and probably install the new one.
And while you are waiting for the calipers, order some speedbleeders (2 required). I got mine from Camautodevelopments. Make sure you get the one for Wilwood calipers!
thank you for the tips :slight_smile:
Apparently the manifold bolt nearest the bulkhead can need a shorter than standard socket. I recall this from an NC video but could be one of those tiny details that stops the job if the ND is much the same.
Be good to hear how you get on. It’s something I’m considering splashing out on…
