Hi,
I have a 2016 Mazda MX-5 ND and recently, I’ve noticed that it’s started making a creaking noise whenever I press down on the clutch pedal. The noise is identical to what can be heard in this video: https://www.youtube.com/watch?v=PkPkdJavRLw. Has anyone else encountered this problem and, if so, is there a solution to it?
Just some more background info:
My impression is that the noise comes from within the cabin (i.e. from the footwell).
I check with my local Mazda dealer if my car is affected by this TSB but it is not: https://www.miata.net/garage/tsb/grinding-noise-from-clutch-pedal-when-depressing.pdf (it seems the TSB applies to North America; I’m not sure if there ever was a European equivalent).
Thanks,
Joe
