ND Jacking
About exchange my NC (Copper red 1.8 Option Pack) for a new ND (Ceramic 1.5 SE-L). I know that the ND does not provide the usual scissor jack.
Over the years I have had my NC serviced and repaired by those who can in dealer garages. However (usually prior to MOT) over the years I have jacked the car up (with scissor jack provided) and removed wheels for cleaning, inspected springs, hoses, Ā unions etc…
I am not confident enough to jack from points other than the scissor jack points and never climb under the car.
I would like to continue this practice with my ND, but during a dealership showroom inspection I only saw plastic trim where I would expect to see marks for jack point positions.
Ā
Forgive my long winded explanation but what I want to ask of from ND owners is  — Ā
" Are there any clearly marked jacking points on the ND for a scissor jack ? "
You have to be a bit careful under there. Plenty plastic in the way but there are steel flanges to get a trolley jack or lift on.
There will (or should be) instructions in the owners manual for this- surely?
I’ve just had a look - page 474 on the online user manual
Ā  HTH
Ā
Time to invest in a trolley jack perhaps? Far safer for you and the car.
You have to look a bit and it is a bit further in than on the earlier cars.
Look at my MK4 underseal how to, there must be some pictures there that show the pickup points
Hi ET,
The storage bracket for the scissor jackĀ is there on the Mk4. You could keep the jack and wheel brace from your current car and use them on the new one.
Alternatively you could buy one from the ā€˜net’.Ā Ā Ā  http://www.mx5heaven.co.uk/product/black-scissor-jack-2/. Ā Ā Ā  http://www.ebay.co.uk/itm/MAZDA-MX5-MK1-MK2-MK2-5-89-05-SCISSOR-JACK-AND-HANDLE-/121919150288. Ā Ā Ā
I had one from my 7 which is adequate for a quick lift onĀ the ā€˜sill’ jacking points but I put a slit piece of heater hose over the sill to stop damage to the paint. Well sad I know!!!
The point to put the U of the scissor jack is obvious when you get under there.
Have fun in the new motor, they are a very good bit of kit for the money, I love mine.Ā
As per Nibor’s advice I had a look at Page 474 of the online ND owners manual, but itĀ seems to illustrate the same reinforced sill jack point positions and jack position marking as my NC. Will have to have another, but closer, inspection when I do eventually get the ND (Tuesday 29/3/16).
I think it only fair that I pass on the NC jack for the new owner so thanks Mad Malc for the advice on where I can buy a suitable jack (with ā€œUā€ location slot) for my ND.Ā
I do have a trolley jack that I gingerly place under re-inforced chassis members, in the hope it would save the car should the scissor jack fail or topple. This is only a safeguard even though I’m never sure of underside damage should the scissor jack fail. Also a bit reluctant to use it on the sill since without a location slot I would fear ā€œflatteningā€ the reinforced sill with the trolley jack.
Interesting to hear that there is a storage bracket for the jack in the ND.
Ā
Not sure what Drumtochty means in the reference to ā€œmy Mk 4 underseal how toā€ . Probably stupid of me, but maybe advice as a search phrase on theĀ site?
Here you go…
http://www.mx5oc.co.uk/forum/yaf_postst87727_Mk4-Underseal-How-To.aspx
H’mm - if there is a jack mounting point in the boot, and the sill is still the same place as a Mk3, then ask the dealer ā€œWhere’s my jack?ā€ which is what I’d do. I can’t see Mazda sticking a mounting point on the car and not providing a jack for it, unless they had second thoughts?
No jack as standard on later MK3 derivatives or on current MK4
The only tools supplied with my ND was a pouch containing 2 towing eyes and a bar also the emergency gunk kit for a flat tyre (All mentioned in the Owner’s Reference Guide) - no jack. Ā I think this was standard kit throughout the ND range, correct me if I’m wrong.
I think the logic for that seeming omission was - no spare wheel supplied with car = no roadside wheel change possible = no jack required!
I got my dealer to supply a jack at point of purchase. You will also need the T-screw to lock the jack in place and the winding handle (my dealer forgot these two items). I requested the jack to enable me to rotate the wheels as recommended in the handbook.
Good point!
This picture shows how far in the flange is on the ND compared to earlier cars with IanH surveying the underside.
Does anyone by chance, have the part number for the jack and Tscrew please.
The jack parts number for the MK3 which was the last car with a supplied jack is
LD47-37-770
The ND parts listing has the same parts number, no listing for a tscrew so I will leave you to search for that.
Probably cheaper just to by a Mazda scissor jack off ebay.
Thanks Drumtochty. Heading up to the Highlands with a few friends in May and would like to be able to remove a wheel if I had to and also for use at home.
Just order a T-screw from your Mazda dealer. They will know what it is. My dealer sent me one in the post within a week.
