ND - Number plate lights
Changed the standard bulbs to LED. A simple job that is a pain!
The numberplate light units are in there tightly. When you do get them loose, they are on 5mm of lead slack and the bulbs seem to be welded in.
Light unit - I gently pulled the wire and it feels like it is stuck down with sticky gunk, so managed to get a little extra free play
LED bulbs only work one way around, so check BEFORE reassembling!
One in and one to go
Total cost £2.99 and two fingernails.
