ND SatNav - Editing Start Point - Is it possible?
I am planning to do a long trip abroad using the inbuilt SatNav. The intention is to pre-programme and store the named daily legs under favourites in the SatNav menu. Is it possible, whilst doing your route planning to edit the “Start Point” to anything other than “Present Position” (say a set of coordinates where your intended Start Point is) so that the itinerary can be checked out without it including the fact that your “Start Position” is where you are actually located e.g at home?
Is this what you mean
Set a destination with a waypoint
If you need to start a route from a different location, you can do so by creating a waypoint.
  1. On the Navigation screen, enter your final destination.
  2. Once the route is calculated, choose the option to add a waypoint.
  3. Enter the alternative start location as your waypoint.
  4. The system will create a new route that guides you to the waypoint first, and then to your final destination.
Cheers Teleman. I didn’t know that way of entering waypoints other than going down the “edit route” means.
The instructions aren’t very informative are they. I’ve used this method once or twice when I don’t take my phone out with me.
Enjoy your trip abroad :+1:
