ND spring change.. just wow
Why did Mazda not just do this spring rate from the factory!
Just nuts how much better and safer the car feels which them. I know the car wasn’t unsafe and was more than capable of going round corners at the same speeds but it certainly felt sketchy at times.
I also got a precision alignment after about 100 miles after the install at A Line in Dudley with the flyin Miata published settings (well as close as the could get) which has also improved the precision of turn in although the car was actually pretty much bang on the Mazda standard spec.
I can only recommend doing this and can only imagine how much better the car reviews would have been with them (not that I’ve seen a bad review) I just don’t think you can beat these for a fun daily at sensible speeds.
Which springs, eibach?
