I’m looking for technical help or recommendations on: __Alloy wheels
Hello all,
I recently changed all four tyres from the stock Yokohama V105 to Kumho HS51 after the NSR tyre developed a buble after what must have been a massive pothole. This car was bought half a year ago as a Mazda approved used car.
The car has developed a vibration in the floor at 68-75mph since changing the tyres. I’ve had a 4 wheel alignment done since the tyres were changed too.
Went to another garage today (didn’t trust the garage which changed my tyres to do a good job), the mechanic told me both rear wheels were ‘slightly buckled’ and was therefore unable to balance them completely. He seemed to be unable to identify the buckle. They also commented on how much weights the front wheels needed to be balanced. The balancing maching read “15; 65” and “10; 70” on the OSF and NSF, respectively. For reference, the rear wheels were “15; 95” and “15; 120” for the NSR and OSR.
I am hoping to hear if anyone has experienced such mild ‘buckling’ of the wheels which prevents proper balancing of the wheels?
They are talking cobblers, you can balance a biscuit tin if you wanted. The wheel could be square and it will still balance. The algorithm used in the machines is very clever, but basically the machine is looking for the very slight speed variations due to weight as the wheel rotates. The weights simply balance out these variances. A vibration at a certain speed is very typically a harmonic situation because they have not taken the time to properly balance it. Many do not check, once the machine has told them where to put weights, that the wheel is actually balanced.
Do you think that is a lot of balancing weight for the wheels? I remember thinking that to myself when I bought it, but they all seem to be opposite the TPMS sensor, which makes sense.
It could be/likely that you buckled the wheels when you damaged the tyre. You can check the ‘run off’ by jacking up each corner and bodging up a simple ‘dial guage’ and rotating the wheel.
Vertical out of balance should be cured by weights as indicated by a wheel balancing machine but longitudinal (side to side) shimmy caused by the buckle may be more difficult to cure with just weights. My understanding of physics is ‘basic’ at best so what do the ‘experts’ think.
If you have caused a bubble in a tyre by hitting a massive pothole you could have damage any part of your suspension as well so it may not be as simple as ‘a faulty tyre or balance’.
Also been advised to contact the company which sold the tyres as it might be a bad batch of tyres given how the other wheels are requiring a lot of weights to be balanced.
The suspension should be ok. The 4-wheel alignment was done by a very respected man in this community and he mentioned that the components were fine.
