I’m looking for technical help or recommendations on: Non-Starting Issue
Hi all, my ND has suddenly developed a problem where when I try to start it it beeps at me, the starter button flashes green and it won’t start. I’ve replaced the battery in the fob and charged the car battery (which is about the extent of my technical expertise), any ideas?
Hi
Silly question have you tried the other key, etc? If its unlocking and locking its not a transponder issue. Sounds like the immboiliser has a fault or is not seeing the key.
Try the fob on the button trick, if not lock the car manually and open manually with the key.
Need to reset the gremlin with the immoboiliser?
Good luck
Hi, thanks for your help, annoyingly it’s an intermittent fault, holding the key closer to the start button sometimes works, but sometimes doesn’t, so scratching my head a bit, it’s due a service and MOT in a few weeks, so I may ask Crewe Mazda to have a look, although I’m not too keen on using main dealers. It’s a 2018 model.
