ND2 Remap - Versatuner
  1. My model of MX-5 is: ND2 2.0
  2. I’m based near: Shropshire
  3. I’m looking for technical help or recommendations on: Versatuner Remap
I’m looking at tuning options for my 2021 2.0 ND2 RF - Weekend car and used for enjoying A and B roads. At this stage I’m just looking into a back-box and remap to complement the car. I’ve come across the Versatuner software which seems quite popular over the pond, but not so much here from what I can tell. I quite like the idea of the slight but noticeable gains from a map to make use of the higher octane fuel and smoother acceleration.
Anyone use/ recommend the Versatuner approach and maps available?
p.s. I know Roddisons and Clearmotorsport (who are a Versatuner approved tuner) are known for ND2 maps just curious about this software and what I could achieve myself.
Unless you know what values to alter in loads of different tables, I would go and see Adam!
I will reach out Adam see what we can do - Just wondering if the base maps you have access to are worth trying out.
The base maps are there to do final tweeking and again unless you know what to change, you might as well see Adam who can do the final tuning for your car.
Another for Adam @ Clear…
Must get along to him myself!
Had a really productive chat with Adam today. Looking forward to seeing what we can achieve!
Excellent!
Great to speak with you yesterday @Harlo and thank you for the recommendation, Chris!
A bit of general info… my understanding is that Clive at AutoTronix does the tuning for Rodders, and while he keeps hold of the physical cable, Rodders has the ECUTek license that is required, so both parties work together on this. This may explain why the package available is ‘manifold & map’, and thus juat mapping isn’t available separately. ECUTek doesn’t support the ND2 at this time, as far as I am aware, but the guys at VersaTuner have managed to crack it.
The ND2 is a tricky beast to tune. The ECU is considerably more complex than the ND1 - it takes 2-3 times longer to transfer a full map’s worth of data, to give an idea. Many of the tables are listed as ‘Unknown’ and figuring out what does what has taken a lot of time and help from a couple of guys I work closely with (Shaun and Sam if you’re reading, thank you! @The_Fonze ).
The OEM map on these is really well done, so while it is tricky to improve the power / torque figures (you might see a couple of ft/lbs and 5-7bhp top end - only really because of increasing the revs, because bhp is a function of torque and rpm), the driveability and smoothness can be improved, plus various functions and behaviours adjusted to the owner’s tastes. There are a bunch of things in there which are visibly aimed at reducing NOx emissions (at the expense of CO, CO2 and HC), which detrimentally impact the behaviour of the car mostly at low throttle inputs and tip-in / tip-out. Increasing the rev limiter and changing the behaviour from that weird ‘running into treacle’ sensation makes the car feel a lot more like an MX-5, and means you drop back into the revs higher up on a gear change. This gives considerably more ‘area under the curve’ when pressing on, so while the car wouldn’t display much differently on a dyno, the improved sensation and acceleration times on the road are noticeable.
The OTS (Off The Shelf) tunes within VersaTuner simply bump ignition timing by a ‘flat’ couple of degrees everywhere, and increase some load limits / torque request values. This has a tendency to make the knock sensor very active, pulling timing everywhere, and in the long term after the ECU has learned the behaviour of the new map can actually reduce power, torque and smoothness over OEM.
Hope that is interesting and helpful!
Great comprehensive overview @AdamR28! My car is so much more enjoyable to drive with Adams tuning work, as I’ve said before the OEM map is flat and unresponsive in comparison.
I can’t imagine there is any other tuner out there currently that delves into the detail and optimises all the available tables like Adam has done.
