ND2 RF dashboard fault - water ingress?
Usual RF story. Soaking wet boot and carpets. So, a roof drain issue. Occurring at the same time is an issue with the dashboard display? The display on the l/h screen (range, fuel gauge etc) is breaking up. Vertical lines showing.
Could the cause of this be water ingress to the electronics?
I think the display fault is one that seems to be showing itself more on these ND screens of late. Can be fixed under warranty I believe if that period hasn’t already gone. Unless the screen has been subject to water ingress it won’t be the cause, you could be correct in water ingress to some connections elsewhere though.
The drains, not sure on the RF models but I guess similar too the soft tops past and present, they’ll need a clean out and check for accumulated debris at the drain points.
For the Multi Information Display which is a known fault, if in warranty then get it repaired quick as I believe it is eye wateringly expensive… otherwise the outfit at the link below claim to repair any cluster display, I have no personal knowledge and there may be others who offer this.
Just had the issue diagnosed at dealer. Fault with panel and needs replacement. Not eye wateringly expensive…. £350 for a new panel plus fitting.
That’s good, I know someone was quoted nearly £2K at one point so maybe volume has brought the price down…
