- My model of MX-5 is: PRHT 2008 NC1 with Bose
Current setup:
-Pioneer da250dab headunit
-Connects2 harness adapters
-Using Pioneer PreOut and not the resister pack to connect.
-Focal isu200 door speakers
-Standard rears
-Unplugged front
I am convinced a lot more musicality can be released by the Focals if I could feed them a few more horsepower. So in the spirit of nothing ventured, nothing gained, I plan to replace the Bose amp with an aftermarket unit.
I have seen various posts on this on miata forums, but just thought I would reach out here to see if anyone has been there and done that on European cars, and has any advice to offer.
1st question is where is the amp? On the Miata forum it is advised as being behind the passenger seat (remember PHRT is different to rag top). Does anyone know if this stays on the right hand side on a RH drive car, or if it swaps side?
Next - I am assuming the only cables I will need to cut/ splice are speaker out, line feed in, power and the blue switch on cable. There are going to be other cables, such as the connector to the roof opener, can all these just be taped up?
For amp selection, I was planning to take the bose out and measure it, then buy something that will easily fit - but again, anyone been there and done that? Any recommendations? Presuming a classD amp for heat control in small physical size.
Do amps come with suitable Jack’s that I can use to slice to, or do I need to think about that aswell.
Hoping for a budget of around £100 to £130 sort of money for this, including any Jack’s etc. Is reasonable? Can stretch if needed, but aware this is a fourteen year old car.
Thanks for any comments/help. I will try to document as I go and post a new thread as a “how to” if/when I do this.
