New hood for an Mx5 mk1 recommendations for suppliers and fitters please
  1. My model of MX-5 is: _Mk1
  2. I’m based near: __North Yorks
  3. I’m looking for technical help or recommendations on: _vinyl replacement hood_
Speak to Paul at The Soft Top Shop in Stockport.
Car Hoods Northern in Lymm, Cheshire are also worth contacting.
Thank you I will have a look. Stockport is a bit further than I wanted to travel though.
Thanks for replying. I’ll look at them too but I could do with somewhere nearer to where I live and a recommendation from anyone who has actually had a hood replaced. I’ve read some scare stories. My existing hood is dry so I don’t want to end up in a worse situation with leaks. Thanks again.
I’ve previously used Carhoods for an NA and would use them again. Also used on a friend’s Porsche hood.
Unfortunately I don’t there’s masses of choice across the country, in terms of recommended options.
Yes you’re right there doesn’t seem to be a lot of info or choice about hood fitting. I’ll take a look at Carhoods. I just want it doing right. Thanks for recommending.
Paul at The Soft Top Shop came to me in Worcestershire to replace the hood on my Mk 2.5. Only took him 2-3 hours.
