I’m looking for technical help or recommendations on: ball joint bolt too long
Hi all,
I have purchased a new genuine upper control arm for my mx5 from mx5 parts, and the new ball joints bolt seems to be too long, any advice on what to do here?
Then it looks a bit obvious, as well as being more likely to slip.
Washers come specified in thickness, inner diameter and outer diameter, with lots of variations possible.
I guess the bolt is 8mm or 10mm, and that size i/d “Form A” washer usually has thickness 1.5mm or 2mm, not thick enough with one washer.
Ages ago at work I had to use some 3mm and 5mm as tacked-on packing washers for 10mm bolt-ups, but these thicknesses are not obvious on a quick amazon trawl.
Hi,Hopefully this will answer your question.(a)use your original Mazda nut if you can as it will probably be the correct length.(b) Space the nut with washer &then fit split pin through the castellated nut as it would be fitted originally.(c) Locktight the threads on the joint & fit splitpin.(d) use a nylock nut as this shows a proper secure fitting whereas lock tight is not obvious to the mot tester & as I have just been informed it is not a failure unless it is loose but I would not be happy to see it on a car & would you like to have it on your car with the split pin in a position where it is not securing the nut from coming loose ?. Pop down to your local hardware shop & take your old nut with you & get a nylock nut the same thread it will also make your mot inspector happier to see a proper job has been done
