I’m looking for technical help or recommendations on: __Daytime running lights
Hello everyone, I have a 2019 SE+ and have been trying to disable the daytime running lights (DRL), but there is no fuse in the 25th position of the engine compartment fuse box (which is indicated as DRL in the owner’s manual).
Quite puzzled as essentially the lower halogen DRLs and LED sidelights are running as DRLs without the 15A fuse in the fusebox.
Has anyone disabled the DRLs successfully? I believe this was one of the last few SE+ models as it has the I-eloop and I-stop as well.
This sounds really silly, but I prefer to have control over the vehicle lights just like aircraft pilots control their aircraft lights even when certain lights are mandatory and probably would be easily automated
" DRLs have been legally required to be fitted at the front of all new EU cars and small vans since 2011, but even though some manufacturers choose to include them at the rear, this is not compulsory".
The above quote is not definitive as my 2013 NC does not have them as standard.
My understanding is, that it is when the original Type Approval for the design of the car was submitted.
MOT - Section 4.2.1.(Applicable for next year)
Daytime running lamps
You only need to inspect daytime running lamps (DRLs) if they’re fitted as original equipment to vehicles first used on or after 1 March 2018.
Defect
Category
(a) Lamp:
(i) multiple light source up to a half not functioning
(ii) missing, inoperative or in the case of a multiple light source more than a half not functioning|Minor
Major|
|(b) Defective lens|Major|
|(c) Lamp:
(i) not securely attached
(ii) likely to become detached|Minor
Major|
I also strongly “suspect” that they are an integral design feature of the headlight unit.
(Robbie will know).
As above a good safety feature.
You also run the risk of delving into the insurance side, which you would have to declare and I strongly suspect they wouldn’t insure you perhaps??
Think you are stuck with them to be honest.
If you did manage to disable them, I’d say that your insurance company would need to be informed. I also that they’d probably take a very dim view indeed of you disabling what is obviously a sensible and worthwhile safety feature.
We’ve all seen the numpties driving around in the dark, or fog with no lights on, this is what DRLs are designed to prevent, only front lights unfortunately.
They are LED, so don’t get hot or use much power, and you’ll have to enable them for your Mot in a few years.
Seems a lot of fuss.
I thought there were some settings for them in the settings menu.
